nightvision
- Mar 7, 2004
- 252
Hi all,
I'm changing my gear lube on a 2005 Alpha 1 today and have a question. I will be pumping from the bottom vent and when it is full and coming out of the top vent I will close off the top vent. Do I continue to use the pump to fill up the lube drive monitor container? Or at this point I can close the bottom vent and uncrew the cap on the lube drive monitor container to fill it up? Thanks.
