change impeller 35hp super seahorse
jhromeli
Hi every one , I am rebuilding a 1959 super seahorse 35 hp , so far I have done points , fix the exhaust plate, new sparks, the engine starts real good at the first time ater 15 years of storage , but i have been Reading a lot in the forum and every one said its very important to change the impeller , in the pee hole i have a moderate good flow of water , so i order the Impeller , and I start today the job , I have a manual , so I thought its going to be a easy job after all I have done, Wrong, first thing I found the three screws of the water pump they were stock , because they were carbon steel, so I have to blew the screws and make a new threads for ? in. , change the impeller and put the pump back , I took the thermostat off , to make sure it is working the pump, I start the engine , no water , I check the key , it is in the correct position , I check the water tubes , they were in correct position , also the main shaft , since it moves the propeller , I took everything out , re check , put it back , no water , the water tubes looks dry in the inside.
One of my question is , does the impeller have correct position , I put it to work in a counter clock wise , is it correct?.
I am thinking about the water level in the barrel i put water until the suction plate , should i put water until the height of the water pump, to prime it ?
What else I am missing.
Thanks every one , sorry about my english.
Willyclay
Re: change impeller 35hp super seahorse
Yes, try again but with water level higher without covering the exhaust relief hole. Good luck with that great old motor!
nimmor
Several years ago I purchased a 59 35 and started the restoration project. Replaced the impellor and couldn't get water pressure. I then replaced the grommets and I could not believe the water pressure. The grommets are the rubber fittings that the copper tubes from the pump go into to to create a water tight fit. You should have 4 of them, 2 on the pump and 2 on the motor. After time the grommets dry rot and develop cracks and will not allow water pressure to build. Hope that helps.
jhromeli
Hi, yesterday i work in the motor and I did this.
1) I put a higher level of water in the barrel , no success.
2) I took the lower unit out again , and with garden hose I put water in the cooper tubes , i took the thermostat cover out and i found i have water at this point and no leakage inside the cooper tubes , that lead me to the pump.
3) I don?t know what else to do , this is a real simple system, and what I see the pump it is not working, could it be the direction of the impeller , when you turn the shaft by hand , it will turn only counterclockwise, clockwise is real hard ?
4) the key in the shaft is correct in the impeller , i double check
any advice.
Thanks to all
CATransplant
Your engine runs clockwise. The arms of the impeller should be trailing when you turn the driveshaft clockwise.
jhromeli
Thanks CATransplant, I think my engine works counterclockwise , at least the magneto flywheel it is the way it turns when working, should i change the impeller to turn clockwise?
F_R
Even if you put them in backwards, they will flip over.
I suspect you are leaking air into the intake side of the pump--especially since you did such major work on the screws.
F_R
AND/Or, do you have the thermostat and the plastic housing with the check valve installed? Leave that stuff out, and it will suck air down through the return tube to the pump.
lindy46
Looking down from the top. the flywheel turns clockwise when the motor is running. That shouldn't make any difference to the impeller - even if installed with the vanes in the wrong direction, they should "right" themselves once the engine is running.
jhromeli
Thanks everyone, yesterday i blow air from the top of the thermostat , and i got bubbles in the water , I have the plastic housing and the check valve installed and working, how do i test the pump outside the engine?
I dont know what else to do..
Willyclay
No way to check one without being installed that I know. Biggest issue is verification that impeller is engaged on shaft key prior to installing impeller housing. Good luck!
jhromeli
hi every one , thanks for all the replays, i took the LU to a OMC mechanic , he saids he found that the housing is damaged, i didnt saw that way, but I am trying to find a new one, does any one knows the correct part number , i check at marineengine.com manual and I found this part number 377533 but they didnt have it , also iboats store doesnt have, i check in ebay and also in google for this part number , but nothing.
Please help. this pump have 2 water tubes is for 1959 Johnson Seahorse RDS21
Thanks to all
Willyclay
i check at marineengine.com manual and I found this part number 377533 but they didnt have it , also iboats store doesnt have, Thanks to all
That is the correct ORIGINAL part number. When I entered that number into the marineengine.com parts system, the response was: new part number 0378348. They show 10+ in inventory at $131.00 each. I searched iboats.com store for it but could not find it. Here's a link to the OMC Parts catalog if you need it:
http://www.marineengine.com/parts/v...ntage-evinrude-johnson/377809/37780900001.htm
I also owned an RDS-21 motor and ran it for ten years mostly in saltwater. Had to replace the impeller several times over those years and never had any problems. I did replace the "plate" below the impeller once due to damage from sand/silt, however, it was pumping water okay BEFORE the replacement. In my opinion, the housing would have to be badly damaged for it not to be pumping ANY water. Unless it has a hole in it, I would expect it to still pump water even if the interior surface is badly eroded. I hope F_R or one of the other experts jump in after this because I am NOT an expert, just an old guy who has been fooling with outboards for 50+ years. Hate to see you spend more money on new parts that may not be necessary!
I recall that Forum Moderator Tashasdaddy had the experience of several BAD new impellers right out of the box for a late 50's J&E35 he was working on a few years ago. I think his self-destructed as soon as he started the motor. I think his experience reminds us to check our new impeller very carefully. You might want to re-install the "old" one and see what happens. Sorry I cannot be more help. Hang in there and you will solve the problem. It is usually the simple little things that we overlook or forget. Good luck!
jhromeli
Hi everyone , just to finish , I finally found the problem. The problem was in the screws that I remade the threads , the one in the bottom it wasn?t seating correct the pump housing, after this fix I have a fountain of water in the thermostat.
Thanks everybody for the advice.
Willyclay
As usual, F_R is on top of the problem! Thanks for posting the results. I hope that great old motor continues to run for another 50 years.
