Hello everyone, yesterday I changed the impeller on my 89 Mercruiser 4.3 Alpha I. So I took the lower unit off, changed the impeller and had issues putting the lower unit back in. After about a half hour of spinning the big shaft and the little shaft, I must have gotten it right and it went in but it didn't seem like it went in correctly. But I tightened everything back up and went to start it in neutral. The prop was spinning like it was in forward gear for some reason. If I'd just give it throttle, forward or backward, it would spin the was way, it would stay in forward gear. If I'd try to go forward or reverse without pushing the throttle button, the motor would shut off. So it's enagaged in neautral and just throttle, but when I'd actually try to put it in gear it would die. I have no idea what to make of this.
Any help is appreciated - thanks in advance.
Konrad
Konrad
