Aight, last month I noticed my LU oil was slightly water-tinged, so I decided to go ahead and change the seals. While I was at it, I changed the 2 prop shaft bearings and the top bearing on the drive shaft. Anyway, all the seals, gaskets and o-rings were changed.
I went out yesterday and checked the oil - milkshake. So, today I pulled the LU, put it under different pressures up to a max of about 15 to 20 pounds. No bubbles at all. I turned the drive shaft by hand in gear and still got no bubbles. The only thing I can't do is put it under a vacuum. Any ideas?
...the only thing I can think of is that when I put the prop back after I changed the seals, it didn't seem to go quite as far on the shaft as before. I noticed it because the rubber toothed washer that goes under the prop nut didn't slide down on the splines all the way like it used to. Maybe the line spool washer under the prop is resting on the seal.....I don't know..
Any advice? Think I'm going to just replace the prop shaft seal and see if that fixes it.
...and yes, the nylon drain plug washers are brand new.
