hunterfishercamper
- Jan 30, 2012
- 26
I have a 1963 18hp Evinrude Fastwin that I will normally run at elevations of 5000'-10000', I'd say 80% of the time. I will be making trips to areas between 1500' and 3000' several times a year. I'm guessing this engine will run WOT until I get to where I want to fish (10-30 minutes) then troll for several hours, then WOT back to camp.
What is the best way to compensate for the loss of elevation? At 10000' I am losing 30% of my power and even at 2000' I am losing 10%.
I will be setting the carb at my house around 5700' so I was figuring on setting it just slightly lean. I can always fine tune it while the motor is running on the lakes. I only run 89 octane (our super unleaded) with sea foam in small engines, never anything less. When I get out of state I run 91 with sea foam.
The manual calls for Champion J4J, AC M42K, or Autolite A21x all gapped at .030". I had been planning on setting the points exactly at .020" (really devoting my time to getting this right on), upgrading to the next hotter plug, then gapping the plugs at .035". Also, with the wide selection of plugs today, is there a better style (ie: ez start, eco, etc) than the old ones? I want to deliver a nice strong spark that will be sure to ignite every molecule of fuel and burn every atom of oxygen.
