Changing belts
further
1996 4.3gs PNCA...I'd like to change out the belts and am having an issue finding heavy duty marine grade ones, as I've read I shouldn't be using automotive belts. Anyone have part numbers that I can use. I think there's 3 of them?
Thanks
jerryjerry05
Re: Changing belts
Didn't know there was any difference in the belts Marine/Automotive???
Any #s on your belts?
Take em off and go to Autozone.
Bayou Dave
Re: Changing belts
I bought my belts right here on iboats. A little more expensive than NAPA, etc, but I got the exact size I needed.
further
Re: Changing belts
Jerry,
Don't know either, hence the question....
DRS,
Yeah I'd like to just order them from here as well but havin a hard time trackin all three down. I can find the alternator belt fine but not the other two. I
I guess if there really is no difference between automotive and marine, (contrary to what the manual says) then I'll take em off and go to autozone or equivalent and match up sizes...
Re: Changing belts
Jerry,
DRS,
Ayuh,.... Same belts,.... Mine all come from Napa, because it's close, 'n quick,...
further
Re: Changing belts
Thanks guys... That clears it up. I will remove and go the nearest auto parts (autozone) for replacement.
cr2k
Re: Changing belts
They just put their own PN on it and tell you to buy it from them at twice the price.
