Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
IF I was to change my 1978 85 HP Johnson to a newer OMC, Would I need to replace the controls< What year would I have to go into before having to do that?
Id like to for simplicity sake keep my controls intact.
A 78 would be using a Red Plug. as the connection between motor and controls. If the newer does not have the red plug then you will need new controls. I believe you will be able to use your existing cables. It's the wiring that will cause the issue.
