Changing fan belt?
My boat is a 1989 Glastron Sierra 165s with a 3.0l mercruiser. I need to change the fan belt as I am getting a black deposit on my flame arrester. The belt itself is starting to show a black powder on it. My problem is that to change the belt, I have to remove or loosen four mounting bolts up front on the engine block. I am concerned I may knock something out of line doing so. Is this possible or will everything fall back into place when I am finished. Looks like I have to remove two of the four bolts and loosen up the other two on the opposite side of the alternator. Thanks for the help....
Grub54891
Re: Changing fan belt?
On one side there is a block that comes out when the bolts come out.you may have to loosen the other 2 but it should
be fine when reassembled
Grub
Don S
DO NOT loosen all 4 bolts.
attachment.php
HT32BSX115
Howdy,
You have a "Fan" on that thing? This is a boat, right?;)
It MAY fall back into place. BUT if it doesn't, or isn't back in place, you could knock engine/drive out of alignment......AND coupler failure would eventually be the result, requiring engine removal to replace it. If it's IN alignment it should stay in alignment using the above Mercruiser procedure........
In general, you should check the alignment anytime you disturb the engine mounts..... AND Mercruiser recommends checking the alignment every year anyway since engine mounts, stringers, etc get rotten and they "move"........... you should also remove the drive yearly to inspect the gimbal bearing, bellows (and the alignment) etc.
For your boat, if you don't have one, I would buy a $40-60 "ebay" alignment tool and learn how to check/adjust the alignment.
ymmv.......
Rick
Duh! No fan:redface:....
Thanks Don. I will follow those instructions and NOT loosen the bolts opposite the alternator.
Thanks to all....
wellcraft-classic210
Master Chief Petty Officer
If you have rusty pulleys that could be the root cause of the belts wearing.
some people even install a spare and zip-tie it out of the way. that way when you need to change the belt again, cut off the old belt, then cut the zip-ties from the spare and install.
