Changing Home Page
Mark42
I just went to change the default home page in IE 6.0.2 and it's low lighted, so are the buttons under it. (Tools, Internet Options, General tab) I can't overtype it. What causes this and how do I change it? I have win XP Pro, and use Cisco VPN, wondering if that has anything to do with it.
Mark42
Re: Changing Home Page
Xcuseme,<br /><br />Thanks for the links. I had just installed ATT worldnet's latest software a few weeks ago from a CD they sent. I bet that is what did it. I normally wouldn't have noticed because ATT Worldnet is my homepage. But now with a new ISP, I want to change the page and see it has been locked. <br /><br />Spyware, hijackers, etc are checked for regularly and I haven't had a problem since using a firewall for a year or so. <br /><br />Just one more thing to add to the list of stuff to fix....<br /><br />thanks again!<br /><br />Mark.
Xcusme
As a rule, I try NOT to install an ISP's CD. Modified Internet Explorer and all of the sales BS with branded versions of a browser are a pain. It's best to learn how to get up and flying without using the CD's, but most folks don't know how.<br /><br />Hope you get things sorted out.
Mark42
Just to let you know, it was the ATT install CD that changed the registry setting for Home Page. It was a matter of running regedit and setting the bit setting back to zero. No more problems. Also uninstalled ATT now that I have another ISP.<br /><br />Thanks for posting the links, the info saved me a lot of time messing around with that one.
18rabbit
We were going to change from our current isp to Cingular to take advantage of a special promotion. Cingular said we would be sent an install cd to load on each computer. Why?...i’m already up and running on dsl, should only need to change the addresses?!? I didn’t need to load anything with my current isp. Needless to say, I decided Cingular wasn’t worth the projected hassles down the road.<br /><br />My experience with broadband is that I only needed to plug in the addresses for submask, DNS, etc, and enable tcp/ip, and everything works! I don’t understand the need to make it any more complex than that. Router works the same way. Wi-fi is similar but uses MAC addresses.
Xcusme
Changing ISP's is painless, really. Since you have a router, it's a matter of changing the settings. If you have DSL now, the router settings will be setup for PPPOE, you enter your account name/password (usually your email address) and click on save to retain the info in the router.<br /><br />If you switch over to a cable ISP, again, reprogram the router. Change the type of service from PPPOE to DHCP. There's no need to enter any account info. They know the ID of the cable modem and know it's your account. Again, save the settings and you're good to go. <br /><br />I've just described the manual way to enter the settings for either service. You don't need the CD from the ISP. If you have DSL, and don't have a router, then you will need to use a small program off of their CD to pass your account info to their system. But you don't need the contents of the entire CD installed. <br /><br />With a router, you can go 2 ways regarding IP addresses. You can have the router issue IP addresses to your machines (turn on router DHCP). In Windows, under Networking, set the computer TCP/IP to "Obtain IP Address Automatically" (same for DNS) and you should be good to go. <br /><br />You can also tell Windows to assign a static IP address too. Click on the button to "Use this IP" and enter an IP address manually (ex: 192.168.1.20) Make the Gateway IP the address of your router, typically 192.168.1.1. Enter the IP address of your router for the DNS entry as well (192.168.1.1) Save your settings and reboot. The trick here is to NOT manually assign a static IP address for this machine that falls within the DHCP range of the router (typically 192.168.1.100===>192.168.1.150). <br /><br />If you plan on using any P2P programs, give that computer a static IP address. You can then go into the setting of the router and do Port Forwarding to steer the data to that computer. By all means disable UPNP in your router, no matter which way you go (DHCP or Static).<br /><br />As for the wireless, dump WEP and go WPA (with a STRONG passphrase--63 random characters). MAC address filtering and trying do hide the SSID are useless from a security standpoint. MAC addresses can be spoofed , and discovering the SSID of your 'hidden' router takes 20 seconds.
