Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
I am changing the water pump impeller on a 7.5 evinrude eastwin,do i have to remove the power head to disconect the shift linkage?Also,where is the cooling water outlet on this engine
You don't have to remove the power head. There should be an access plate on the side of the shaft with a 3/8 head hex nut. Loosen that up and kind of pry the linkage apart. Take off the spacer that is nearest the propeller and there your impeller should sit.
