changing long to short shaft
412lorie
is it all possible to change long shaft to a short shaft. is it a major production if it can be done?
roscoe
Re: changing long to short shaft
It depends on the make, model, and year of the motor.
tashasdaddy
changing drive shaft, water tube. can be major. get a jack plate like i said in the other post.
Solittle
With my 12' tinny with a 9.9 longshaft I didn' bother - runs just fine - could run better with a short shaft but not woth the bother to me.
jspringator
When I was shopping for my motor on e-bay, I noticed several incomplete conversions for sale, all in various stages of disassembly. If I couldn't make the long shaft work in my application, I would sell it and get something that would work rather than take it apart.
Chris1956
On the fifties and sixties Johnnyrudes, the conversion from longshaft to shortshaft was easy. You needed a new short driveshaft and a shift rod connector. You then removed the midsection extension, driveshaft cover, and water tube extensions, and installed the new driveshaft (simply pull out from the gearcase) and shift rod connector.
