86strados169v
- Feb 24, 2007
- 12
Does anybody know what effect I will have If I change from a 2/1 to a 1.87/1 ratio? How will it effect prop size? will I need to go up or down? Thanks
My problem is that I hit a rock with the prop and bent the shaft on my lower unit ! I have been looking around for a used lower unit and I have only been able to find one with a 1.87/1 ratio and I have 2/1 ratio right now! If change to a1.87/1 ratio I don't know what prop to go to. I have a 24p 4 blade right now but it was bent as well so It will have to be replaced ! I'm in the process of trying to take my lower unit apart to see how the gears look. If they look good I will just get a new shaft, bearings and seals for the lower unit I have and put it back together!Don said:What is your problem? Whatever it is, I doubt you suddenly need a gear change to cure the problem unless you have changed altitudes.
Also, what Year, Make, and model engine do you have?
