Changing Mecrusier 4.3L Sparkplugs?
hostage
I am thinking of changing my sparkplugs for my 4.3L Mercrusier. It is a 190hp w/ an Alpha 1 Gen II outdrive year - 2000. I have never changed spark plugs before, only car brakes and car oil, how hard is it? Also, what type of plugs should I get and what gap should they be set for?
Thanks in advance,
Hostage
ryanr623
Re: Changing Mecrusier 4.3L Sparkplugs?
Thanks in advance,
Hostage
Pull off spark plug wire (one at a time, not all at once)
Unscrew spark plug
Screw in new plug
Put on boot
repeat on rest of engine
Get the same spark plugs that you pull out of the engine.... so longs as it ran well with them in.
dingdongs
Do not tighten as if your holding a wheel on a car.Tell us what plugs you have as most people go down the NGK plug road.undo cap and have a look at the 6 pick ups.if they look like chalky deposits on them clean them up with screwdriver etc.when did you last have an impellor change in the drive?
most of what you are looking for can be viewed on youtube to give you an excellent video of how to do general maintenance on your mercruiser engine and drive.
hostage
I had the impeller changed along with all the bellows, and throttle cable a month ago. My mechanic changed the dist cap as well.
AZSenza
Dont know if youve tackled this yet but to help start the plugs and not strip them, use a length of hose about a foot long 1/4" diameter, slip it over the terminal of the plug and use that to start it. It really helps with the odd angle and big manifolds.
  • Like
Reactions: zul
odie241
Also,to make it easier to change the spark plugs the next time,put a little "Anti-Seize" on the threads of the plugs.I do this on every car I work on at work,plus my own boat.
