Remove the vertical throttle shaft and inlet gas hose.
Remove the nut from the other one on the other side, and the front one also.
Remove the clamshells from the lower mounts
Grab hold of the lower unit and powerhead and rotate the entire motor out of the steering bracket (lower unit to the rear and everything up and out).
