Changing my boat gauges.
catfishr1
Started changing my boat gauges. First thing noticed PO did not follow code for wires. Everything seemed OK till changed temp and tach, Everything went south. Now have no gauges. The tach worked until yesterday. Figure probably a dead short. 20230617_073713.jpg
alldodge
Going to be hard for us online to know what's wrong. Do you have a volt meter, and if so check power and connections.
catfishr1
Yes, it is not very good. Think will buy a better one so can be sure of readings.
You probably noticed left volt gauge original.
Do have one ?. Noticed some of the gauges had what appears to be a ground and a hot wire wired together and on the positive post. Thought this was very strange. Wiring is not my strong point however feel if get a good meter and some guidance can fig. it out.
catfishr1
Plan on working on it this evening. Will try to get some pics.
alldodge
All Iboaters will be here to help, just may not be quick responses, but we will be back
mike_i
Ensign
"Noticed some of the gauges had what appears to be a ground and a hot wire wired together and on the positive post"
I hope not.
catfishr1
Here are pic's promised. Used my old meter this morning. 3 volts fuel, 3 volts trim, 6 volts tach 1st reading, 3 volts temp., and 3 volts voltmeter. 2nd reading 8 volts tach, rest the same. Tach started working again? Guess you can see what a menagerie am dealing with. If PO would have adhered to code this would be much easier.
alldodge
Unable to determine what manufacture but do see some corrosion issues. Maybe remove wires, clean and reinstall may fix the issues, or at least some of them
catfishr1
By the way all dodge that is an outstanding schematic of gauge hook up. Thank you.
catfishr1
Nene to determine what manufacture but do see some corrosion issues. Maybe remove wires, clean and reinstall may fix the issues, or at least some of them
The new gauges are crowline black sterling. The old gauge just says starcraft.
Will try cleaning as you suggested. Did notice corrosion.
Gauges are easy
I = Ignition (purple)
GND = Ground (black)
L = Light (dark blue)
S = Signal
tan = water temp
light blue = oil pressure
grey = tach
pink = fuel
catfishr1
I should probably mention trim gauge did not work when I purchased boat. Blower quit last year, however was able to hook it directly to battery. Now won't work at all. And fuel gauge been acting weird.
check your grounds
catfishr1
Got my new multimeter today. Going out now to get readings. Did notice yesterday tach works as long as revs. about 900 or more. Does that mean got a short?
alldodge
Not necessarily, might just be a bad Tach, but bad Tach can cause ignition problems
catfishr1
I got good readings today. Ign. on 2.6 volts fuel, trim, water temp, voltmeter, 6 volts tach.
Running 9volts tach, 4 on rest.
The engine starts right away, every time.
04fxdwgi25
Did you mean 12.6 on temp, trim and fuel?
What you mean by "4 on rest" ? Supposed to be 14?
Are you sure the tach is set to proper setting for engine size / cyl?
What is that yellow wire connected to ground?
Lou C
If you have one of those old original fuse boxes with the glass fuses check the tabs for oxidation; I had this problem one year & none of the gauges came on & engine didn’t crank. Fuse was not blown it was simply oxidation.
Did the old gauges work right?
catfishr1
Have checked readings several times, definitely 2.6 on all but tach. Have tach set on 6cyl 3p. Going to hook up my timing light to make sure getting accurate reading.
