Hi all,
I have a 1964 Hydrodyne runabout that is near and dear to me (to answer the inevitable replies of "get a different boat"
It has a 289 Ford V8 mated to an Eaton Powernaut outdrive. The outdrive is pretty well shot, and as part of the boat's restoration I would like to update to a better unit. Would definitely like to have tilt/trim. The transom is getting replaced, which gives me some freedom as far as the cutout and modifications.
I don't have a lot of experience with sterndrives, but from what I understand if I want to keep the current powerplant (which I do), I'll need to look at Volvo Penta's since they can mate to a Ford engine and Mercruisers cannot. Please correct me if I'm wrong here, which is likely...
My question is - what would you guys recommend? It's a 17' fiberglass boat, after a little tweaking the engine will make around ~220hp. I would definitely prefer to keep costs under $2k for the outdrive, even if it means piecing one together.
Thank you in advance!
- Jeremy
- Jeremy
