changing outdrives
ringmaster
i ran into a guy the blew his outdrive up its a 20' starcraft aluminum boat with a 140 4cyl and a 1.98 gear ratio outdrive. i have a 1.84 that came off a 4.3. i looked in my manual and it shows the 1.84 for a 120 engine the wot rpm is the same for the 140 and 4.3. will this outdrive work for him or will it be to much?
Re: changing outdrives
Ayuh,... That Info don't sound right,... You might be able to prop it Down enough to run the 140hp...
dan t.
you are talking only 12/100 difference in ratio ,I would try it
