Changing Thermostat on 3.0L - Which Parts?
enginesilo
When changing the thermostat on a 3.0L, should I change the thermostat and the top gasket only? Anyone recommend also changing the sleeve and the lower side gasket? I can see those 4 parts in the diagram but it seems like most of the kids only have the top gasket and thermostat. Is it common to change those other 2 parts?
Parts I am referring to are:
Thermostat And Hoses(Standard Cooling)(S/N: 0L341000 And Up)
Thermostat Part #807252T2
Gasket Part #331792
Sleeve Part #806922
Lower Gasket #806871
PS-I still can't believe Don S is gone :blue:
oldjeep
Re: Changing Thermostat on 3.0L - Which Parts?
Thanks for the specifics. So that kit you posted shows different "Replaces O.E. Part #'s". Is that the right one for my engine?
Not sure, but that is the kit I use on my 2005
Fun Times
The Mercruiser kit number is 807252Q5 that would crossover to sierra marine Part # 18-3647 that's found here on iboats,
807252q5 - iboats
