Re: changing thermostat
Put them back on as normal with the clamps. A good tip is to remove any rust/scale on the inlets with a wire brush and clean the inside ends of the hose. All should be good. Using a sealant on the hose connections will just make for a messy and hard time when you want/need to take them off again.
