Hi. Mercruiser Alpha 1 outdrive. Existing prop was a 3-blade aluminum (19'p I was told, but can't find it on the prop). I'm putting on a Piranha 4-blade - I have 18p and 16p blades for it. Here's the question:
I slide the old prop off but the Piranha only slides on far enough to put the prop nut on about half way. I'm doing this under water, so I feel another washer on the shaft (large washer on the base of the shaft) that is keeping the Piranha from sliding down all the way. I don't know what this large washer is for - is it for the previous prop and removable to install the Piranha? or is it ALWAYS need to be on there?
The Piranha seems to fit on fine if I remove this washer. Is this OK?
