You've only got one back so get a neighbor or a friend to do the lifting. It's really not that heavy, I'm certainly not the biggest or strongest around and I can manage mine fairly easily even with Stainless Prop.
I would
Tilt the motor up to a comfortable working height.
Leave the 4 nuts that you can see a couple of turns onto the studs and remove the nut at the bottom (the one you can't see) completely, break the the lower unit away to leave the weight resting on the 4 nuts = lower unit is free and no lifting by you.
It's then the work of a moment for someone with just normal lifting ability to remove it the rest of the way.
Getting it back on is slightly more work because you might have have to play around to align the splines, but again it's really not so hard.
1st time around a few seconds to lift it off, less than a minute to get it back on the where no more lifting is required.
