changing zinc behind prop on vp 290 sp
jfalco
how do i change the zinc behind the prop on my 1988 aq211 with 290 sp drive, do i need any special wrenches, i read the manual and it talks about long hub and short hub and doesn't explain the procedure to well, i have a long allen bolt through the nose cone if that helps, also do i need a prop puller or does the prop slide off easily?
