chaning vro to a straight fuel pump
windshadow
does anyone know what the part number is to replace a vro pump with a straight fuel pump on a jhonson 1995 70 hp ? do you need to do anything to the motor after you do this change thanks bill. buy the way I had the top end done at the shop for $1900.00 that included water pump and carbs rebuilt.
tashasdaddy
Re: chaning vro to a straight fuel pump
Pump BRP # 438559, is a 3 hose, pump for a 70 hp. fuel inlet hose, outlet hose, and pulse hose, you will have to find a place to mount it. remove the OMS pump, and disconnect wiring to it. and to oil tank. Premix you fuel 50-1 TC-W3 oil, before you run the motor, make sure you have primed the premixed fuel all the way to the carbs.
windshadow
ok thanks for the link so I would use the 438559 with my 1995 70 just make a mount.
windshadow
thanks for the info ,I think for now I am just going to disconnect the oil feed line plug it and disconect the plug from the oil tank to the motor an run with that for awhile and see if she runs good ,and if not I will change out the pump thanks bill.
windshadow
ok I have done alot of reading about this vro pump deal.the shop I was using for my engine work said they hardly ever see any engines still hooked up to the vro and the shop that is doing the power head rebuild said he thinks the vro should be unhooked? now after all the reading I see it is about 50 to 50 on if the vro should be unhooked. Now I am not sure. I will say this I think from the sounds of things I may have had carbon buils up or a carb or two running lean the bottom two cylenders when out so I do not think the vro was the problem,just not sure what to do ?
tashasdaddy
when i'm in doubt. i make sure my motor is getting oil, i disconnect and premix. i know there is oil then.
Dhadley
First of all your motor didn't come with a VRO. It came with the newer OMS pump. I'd be real leary of a shop that wants to rebuild the motor and does not know the difference. Any OMC/BRP injection pump cannot stop oil going to one cylinder. Carbon build up has more to do with top capable rpm than the fuel/oil pump. A restricted or dirty carb will not be cured by a new fuel pump.
The OMS pump does several things you can't do manually. If, in the future, a fuel restriction develops the pump will automatically pump more oil. That alone may save another rebuild. It will warn you if the oil level is low and you forgot to check. Then it will warn you if there is no oil flow. None of that can happen with premix. Forget the oil in one trip and it's probably toast. Develop a fuel restriction and you'll never know until it's too late.
Personally I'd never run another 2 stroke outboard without oil injection.
windshadow
well I had the line plugged and wires disconnected were they need to be, I will be running my own oill gas mix. I already new it was oms same thing differnt name. the shop did not call it a vro I did,as for forgetting to put in oil well it may happen but I do not think I will forget after what I just spent on this repair. thanks every one for the information bill.
james williams
QUOTE``I am with you on that one now i know the oil will be there all the time . bill``
I had used two-strokes for twenty years,never forgot to add oil.In 1970 I slipped one time.My memory of what that did to me.Last dollar I had to buy that brand new 1969 100hp Johnson went up in smoke.But every body`s not stupid like me.Just do`nt forget to add oil,hang a tag on the key, james
windshadow
got ya james its kinda like my mowers for my lawn biz if you mix yuor oil your equipment just keeps going I kind think the same goes for out bords not to say it cant happen but I am not worried obout my end of adding oil thanks for the heads up .
kenmyfam
Big sign saying "mix oil at 50:1" on the filler works wonders for me.
