I was told that the regulator and rectifier are one piece and will cost 140 dollars. At times the voltage stays at 14v then rises to 15.5v after a time. Should I replace it. John {callieann]Originally posted by callieann:<br /> Thanks I will check it out and let you know. Go steelers
Originally posted by RodC:<br /> My book states that all 40hp models prior to 1993 had the 9 amp stator without regulator. The 1993 and up models of the 40-60hp included a voltage regulator. <br /><br />Are you sure you have a regulated system ? Can you describe the regulator/rectifier ? The rectifier should be square and have 3 posts or studs with wires attached. The regulator/rectifier should be a molded plastic case with 4 wires coming out of it.
