Re: charger for battery
Let me see if I can bring some clarity to the issue, I am a EMC engineer and am involved with power supply designs on a daily basis, mfg's don't necessarily provide the best charger for the product, they look at the price point they want to hit and try to decide where they can cut cost with the least hit on the function of the product.
That said, the bulk charger is the least expensive way for a mfg to go, the charger will take the longest time to charge the battery with out over heating it when its pumping out its peak current, with a bulk charger it is a non linear current output, what that means is when the battery is discharged it will pump out up to its max current as the battery takes on its charge the current drops off because the internal resistance goes up.
With a 8Ah battery and a 500mA charger it would take much longer then the 16 hour you would think to charge the battery because of the tapering off of the current.
With most of the new smart chargers they go about charging a bit different, on a discharged battery they will go to full current and charge for a period of time, then they stop sit and wait a minute for the charge to stabilize and measure the voltage at the batty evaluate were the battery is in the charge process and then continue on until the battery is charged, the difference between this process and the bulk charger is the smart charger can go over typical peak voltage for the battery when its in the later charge process to actually charge faster then a bulk charger would, higher voltage with the same resistance equals higher amp output, as the battery gets closer to being peaked out the current output is pulled back by the processor in the charger until the batty is fully charged, at that point the charger just sits and monitors the voltage until it sees its dropped below as specified level and then it goes into the last stage charging process again until its peaked out and just continues to repeat.
this process is actually better for the battery and less damaging in the process of charging and potential over heat situation.
The battery tender is a very well designed charger and actually would be a better choice then the bulk charger supplied , sorry for the winded story.
Regards,
Kent
