Charging a trolling motor battery
golfnut123
I just bought a Johnson Seahorse Mod#j35ecsm. I also have an ancient trolling motor with alligator clips that go on a battery. Can I put a seperate battery in the boat for trolling and have it charge from the outboard?
M
Mod3
Guest
Re: Charging a trolling motor battery
Moving to Electrics, Electronics and Trolling Motors.
DHPMARINE
You can do it,but that 35HP charge system barely puts out enough amps to charge the battery for it's own use.It will never be close to what a troll battery needs.We are probably talking 4 amps or less output.<br /><br />DHP
golfnut123
Thanks. That's kinda what I thought. Looks like I get to carry the battery back and forth from home.
Silvertip
If you have power at the dock, install an on-board charger and plug-in when the boat is at the dock.
