forrestforrest
- Aug 1, 2008
- 4
I bought a 3 stage rapid charger and an Optima Marine DeepCycle AGM battery and want to go fishing tomorrow, the manufacturers are closed:
The charger requires me to manually select deep-cycle, regular or AGM/gel cell. I can't pick AGM AND Deep Cycle!
It also has settings for 10A,6A and 2A.
The charger manual was not much help.
I got these spec from the optima site:
Alternator: 13.65 to 15.0 volts
Battery Charger (Constant Voltage):
13.8 to 15.0 volts; 10 amps maximum; 6-12 hours approximate
Float Charge:
13.2 to 13.8 volts; 1 amp maximum (indefinite time at lower
voltages)
Rapid Recharge
Constant voltage charger)
Maximum voltage 15.6 volts. No current limit as long as battery
temperature remains below 125?F (51.7?C). Charge until
current drops below 1 amp.
Cyclic or Series String Applications:
14.7 volts. No current limit as long as battery temperature
remains below 125?F (51.7?C). When current falls below 1 amp,
finish with 2 amp constant current for 1 hour.
All limits must be strictly adhered to.
3 questions:
1)I think this means that I can charge this battery at 10A until I hit 15.6V and then manually stop the charger. Is that right?
2) is the proper selection AGM or deepcycle?
3)what is "cyclic or series string applications" mean?
any good advice appreciated
forrest
Float Charge:
voltages)
Rapid Recharge
3 questions:
forrest
