NigelzFling
- Feb 15, 2004
- 10
Hi y'all,
<br /><br />Maybe I'm missing something, but when my battery went flat I took it out and charged it at home, then put it back in the boat.<br /><br />It started beautifully
, but when I put a Multimeter across the Battery terminals, it read just over 12 volts
....therefore I assumed the charging circuit is bad.<br /><br />When I chased the thick wires back from the battery all I found was the Negative (Black) went straight to the Powerhead case and ended and the Positive (Red) went to the Starter Solenoid then to the Powerhead case and ended.<br /><br />Hmmm
, there are also smaller guage +ve and -ve wires coming from the battery terminals, but I can assume these are for the accessories.<br /><br />So, is it normal for a Evinrude 115 fitted to a OMC Turbojet in a Fling "NOT" to have a charging circuit
?<br /><br />If I should have a Battery Charging Circuit, where should the components be
?<br /><br />If someone is keen enough I can take some pix of the powerhead and email them to you to try and sort things out for me
.<br /><br />Thanks in advance for your valuable assistance
.<br /><br />Nigel
