Charging coil test 560 OHMS ?
dh703
I have a Johnson 1978 V4 115Hp M#115ML78C and according to the chaging coil test teh resistance should be 560 Ohms with a low end tolreance at 480 ohms, this is between the A & B pins on the connector. Mine is at 297 ohms. Will this cause a low charge spark or just lower then the rated 6 Amp charge on the Battery?
