Charging deep cycle battery off engine?
lrdchaos
I have a two battery setup with a deep cycle for when I’m anchored out and a starting battery for our 350 mag. Is there any reason why on the longer runs I cant turn my battery selector to the deep cycle, by itself, and charge it off the boats alternator?
JASinIL2006
I don't think there is any reason you couldn't do that... an ACR does essentially the same thing when the starting battery is fully charged.
crazy charlie
I prefer to have both batteries "on" for long runs and have both of them charge.Remember to turn one off when you reach your destination.Charlie
dingbat
You will have no problems unless a battery fails on you while combined.
Just keep in mind that anytime you "combine" batteries you are physically combining the two and they will equalize their outputs.
A 12.7 volt battery combined with a 11.2 volt battery makes for one large 11.95 volt (dead) battery.
Like wise, if a battery goes bad for one reason or another, ie. shorted or dead cell, its possible it could damage both batteries. Seen it happen twice.
You would be better off to stop playing switch roulette and install an ACR.
Best $100 you can spend on a boat.
