charging problem 94 force 120
Mike NZ
Re: charging problem 94 force 120
Just been down that track. Stator . Some dodgy wiring under the flywheel failed and cooked the stator. All the best Mike,
91formula
1) how old is the battery, 2) My tach was reading like 9-11 and was always bounting around, thought it was the rectifier, it wasn't finally had my checked out my tach, it was broke, start small, tack, then check charging system, battery when running, rectifier, then stator,
hagman
Thanks <br />A) How do you check the stator?<br />B) How do you check the rectifiier?
