Re: charging question.
agreed Eddie
i see no reason why one wouldn't be able to run two batts on that charging system, assuming it is in good working condition
make sure the current system charges the one battery well - roughly 14.5 volts at 1500 rpm
also would be a good idea to check how many amps the current system puts out
as stated, a two position battery switch is a good idea, it allows one to charge both batteries while running and use only one for anchoring/listening to tunes while the other stays fresh for starting
