Re: charging system on 1150 thunderbolt ignition
These are readings I got on my 76 115 hp. It was not charging when I got it, so I replaced the rectifier. BTW, I also ended up having my batteries tested. They were all bad, so I ended up buying new ones.<br /><br />New rectifier arrived today and installed. Charging system now seems to be functioning. These are the various readings I got on my Fluke multimeter. Please tell me if you know if these are normal. It shows that I atleast have some sort of charging going on.<br /><br />Battery w/motor off = 13.33vdc<br /><br />Battery at idle = 14.35vdc / 5.6amps<br /><br />Battery motor idled up some = 14.90vdc / 6amps<br /><br />Readings at rectifier/ motor idling:<br />non + =8.3vac / .7amps<br />other non + = 8.3vac / .7amps<br />+ = 14.35vdc / 5.65 amps
