OK this is the setup that I now have.
the engine is the "refridge" using battery number "3" in the pic, the other two batteries 1 and 2 are the house batteries.
I have a jumper between the two switches just in case my engine batt dies by switching the 2nd dual switch to both or num 2.
after searching this forum and learing that my 03 f225 has a auxillary lead for charging a second battery I have a few questions.
first I believe that the auxillary lead has been untilzed by the previous owner because it appears that the wiringing harness on the starboard side has been tapped into. That wire then runs to the 3 bank isolator like the pic above.
The isolator is a single alt, 3 bank design.
I need to know if I should have the the isolator output wire connected to the engine batt or does it get charged directly via the pos cable?
If I do have the isolator output going to the engine batt will that effect the charging of the engine battery or other batteries.
my guess is it wont matter due to the isolator which will distribute the current as needed,
might it effect the engine battery being charged?
I could easily remove the isolator output going to the engine battery if the main pos cable is charging the engine battery.
any thoughts?
thanks
wayne
any thoughts?
thanks
wayne
