Re: charging system
If you like the idea of replacing parts (the bolt on variety) to see if you can fix the problem, try another rectifier (triangular shaped, probably 4 wire connection) -- best if you can get a used one known to be good, other wise you can pick up a new one for between 30 and 40 bucks. (NAPA probably has it in a Sierra after-market model.) The rectifier is usually a pretty good bet.
