I have just winterized the engine and performed a few checks as per the manual. The first was a vacuum check which at 600rpm the needle varied between 16-18 in Hg very fast. The manual seems to say it should be steady and a reading below 18 is the sign of problems. I then checked compression which was 4 cylinders at 150 , one at 160 and one at 170. The engine fires first time and achieves WOT with no problems. Does anybody think I have a problem (mechanical!). Engine is Volvo Penta 4.3GL 4 years old.<br /> <br /><br />Regards<br /><br />Chris
