check ball style t-stat housing -what are the balls for?
fishingdan
I have a 1991 4.3lx mercruiser. I'm troubleshooting an overheat problem. While poking around, I see I have the t-stat housing type that has the check-balls on the lines that are connected to the exhaust elbow.
What is the purpose/function of those check balls? With the t-stat housing off the boat, should the check balls be snug against the nipple? Mine have a gap on one end or the other.
Thanks
jerryjerry05
Re: check ball style t-stat housing -what are the balls for?
That's to make sure the water only flows one way!! Don't remove them.J
cadunkle
The check balls restrict water flow to the risers, ensuring enough cool water will flow through your engine block. I had an overheat problem I couldn't figure out for a while. Eventually I thoroughly cleaned the thermostat housing and check balls and stretched those springs out to put more tension holding the check balls.
Symptoms I noticed while engine temp climbed was risers were cool to the touch. I also had plenty of water flow out of the exhaust.
fishingdan
Thanks for the responses. When I look at the t-stat house out of the boat. Should both balls be snug to the nipples? I suspect yes. If that is the case, I probably need to disassemble, clean it and adjust it. Currently, 1 ball has a gap between it and it's nipple when the other ball is snug.
fishingdan
Thank you
