Check engine light and alarm goes on
sfmaster
Hi,
My 2000 150 hp Johnson alarm and check engine light goes on when I'm at 29 rpm. I slow down and the alarm and light goes off. The motor never stalls or shows any signs of failure. What could it be?
Thank you.
Chris1956
The "Check Engine" alarm is a fuel restriction. See if the main strainer plus any fuel filters and water separators you might have, are clean and not causing a fuel restriction. Also, the main fuel line should be 3/8" inside diameter (ID), for proper operation.
boobie
Check it with a vacuum gauge according to the service manual and you should find the problem. It's never failed me yet.
