After needing to be towed in I can recommend something to be checked periodicaly
like regular maintenance.
On my 3 cyl 2cy 90hp outboard the nut holding the starter enagement gear in place worked its way loose. Consequently when I went to start it the gear just ran up the spline of the starter losing its engagement. I believe that this was something that was slowly happening over the last 17 years and finally the nut just popped off.
I put it all back together and this time used some blue loctite that I will look at periodically to make sure that the loctite seal is not broken leading to a repeat problem.
Not sure how common this is, I would have never thought to check on this but its on my list now.
Anyone experience this or is it a 1 off kind of thing?
