I am installing a fule water separator that will be above my fuel tank. According to the diagram that came with the fuel filter I should install a check valve in the fuel line before it goes to the fuel filter(see picture.I am using a different model filter but this is the same diagram that came with mine.)Is this necessary or will a primer bulb act as my check valve? Thank you
