Re: Checking a 1985 Force 50 water impeller
Ok. Took lower unit off. It looked ok, but was going to replace anyways. Thanks for confirmation. So I slip the cup and impleller over top of the shaft. But there is a , what looks to be, a stainless steel seal or sleeve. Do I just slip that off as well? Also, the copper tubing which sets in the impeller housing fell from under the motor. This looks to be a pain to fit back up in there as you can see where it connect into. Should I open another post for that?
