woodsyfeller
- Aug 15, 2011
- 182
I want to check the compression on 80-81 mercury 140 straight 6 that has the thuderbolt ignition system. I was wondering is there a chance I would damage any of the elec/igniton system if I spin the flywheel to check for compression without the wiring harness attached to the motor.Should I hook up the wiring harness and battery? The engine is not currently on a boat but on a stand.If I should hook up the harness and battery would it be a big deal to use the starter to turn over the engine without it being in water or will that damage the impeller even though the motor isnt going to actually be started just turned over a few times for compression readlings.
Should I spray some fogging oil or some other product into the pistons when doing this to help lube the piston walls ect?
