Re: Checking compression
Yes the powerhead is off. Before I pulled it, the compression was good. I just want to make sure that everything is OK before I put the head back on.<br /><br />Some Background. It's a Merc 174hp V6 1987. Engine was stalling at low speed, hard to start, backfiring. While doing a cpmpression check found water in #1 cylinder, replaced the head gasket on that side but found small nicks in head, cylinder and piston looked ok. Couldn't find any debris in cylinder and the cylinder an. Replaced head gasket. Checked compression all 6 between 120 and 125. Seemed like I had it fixed until I tried starting it. Had all of the same problems and one new one. Engine made a distinct metal on metal knock or rapping sound. Mechanic who heard it said, "somethings broke, get a new powerhead". Don't have the $$ so I'm opening it up to see what's up.
