Checking compression
JRegier
Just wondering if anyone had tips for how to check compression of a loose small engine powerhead without it being installed to a recoil
Will Bark
Re: Checking compression
You could try using a drill with a socket on the nut to the flywheel and spin the engine that way; you would need to secure the engine. Good luck
nwcove
"most" small ob's....and some large ones have a rope sheave on the flywheel. clamp the powerhead firmly in a b&d workmate or similiar type clamp.
boobie
I wouldn't recommend using a drill and socket on the flywheel nut as you could screw up the nut torque on the flywheel.
boobie
I'll stick with the compression gauge on a 2 stroke. The 4 stroke is a different story.
HighTrim
Plenty times. Just be sure to secure it somehow and test away!
Couple of bolt thru a 2 by 4 and clamp it in your bench vise or to a hefty table.---Pull the cord.
JRegier
thanks for the suggestions everyone. Sounds like something to do in the spring. I don't feel like going out in the cold :D
