Re: checking ignition coil
Quick and simple way, make sure you have 12 v to the positive side of the coil, pull the secondary lead off of the distrib cap, hold it 3/8 inch from a ground and crank the motor. Should get a good healthy arc across the gap<br /><br />If you don't, check the voltage to the coil as you are cranking it. (yeah, I know. Not enough hands). Should be minimum 8 volts. If you have sufficient voltage but no arc, I'd suspect the coil is bad.<br /><br />Someone else may have the correct technical way to check the coil but the above should work.
