Checking out a 115 Yammy 4 stroke!!!
LindenLongRods
Thursday I'm gonna check out a boat, The motor is a 115 Yamaha 4 stroke. Do I do a compression check like I would on a 2 stroke? What are the steps for a compression check? What should it read? I will check the lower for milky white. Is there anything else I should be aware of? The boat is a 2000 so I'm guessing the engine is also. Any help will be greatly appreciated.
CATransplant
Re: Checking out a 115 Yammy 4 stroke!!!
Yup, same compression test procedure. Checking the lower unit oil is a great idea, too. Best idea of all, though, is an on-the-water test run. If that's possible, I'd sure do it, especially for the amount of money you're likely to be spending.
tommays
Well
If you were in the Yamaha forum Rodbolt would say go with a leakdown test as it would show the condition of the valves as well as rings
andymach23
It would be good to get a look at the crank case oil if possible after a good run.
I bought a used Yamaha F80 on my boat and when I changed the oil a couple of months down the line before launching, it was pure white due to water ingress.
The pre-purchase surveyor had run the engine with water contaminated fuel. The motor then went to the Yamaha shop who cleared out the carbs etc. I The Jackass didn't change the oil though.
I changed the oil a further 4 times before launching after running for an hour on the hose. The oil was still a bit cloudy after that. I've launched now and will do a change soon after about 10 hours running. Hopefully it will be ok.
If I had of thought I should have at least had a look at the oil on the dipstick and maybe smeared it on something dark.
Someone sneaky could put fresh oil in I suppose, to hide something.
A warranty on the motor would be ideal to cover yourself.
