checking volts
russeller
i have a 66 rude selectric shift with a gen and starter was wondering if there is a way to check to see if the gen is charging the battery?
Hooty
Re: checking volts
Sure. Check the battery voltage with the engine running and not running. If the voltage is higher with the engine running, it's charging. If it ain't, it ain't.<br /><br />c/6<br />Hooty
BoatBuoy
Re: checking volts
BTW, same check works for vehicles also to determine if alternator is working.
stairliftoheaven
Re: checking volts
with engine running you should be getting at least 13.5 volts across the battery terminals
