Chevy 350 rebuild....chip at bottom of cylinder
rotor_av8
I have a chip at the bottom of one of my cylinders on a 350 chevy I am rebuilding. Do you guys think this block is useable? Isn't this well below where the rings will run? Will this create a weak or hot spot? This engine threw a rod from a valve hitting the piston. I'll include a pic of the rod too because it is kind of fun.
I had to squeeze it together some to fit it out the cylinder bore. I'll tell you it wasn't easy. I was 30 seconds away from getting the sawzall out to cut it off. I only put the effort in so i could show it off. I used a high lift jack to squeeze it together...LOL
The main pic is on the bottom of cylinder 4 on the inside near the camshaft.
Let me know if you need something described better. I plan to build this engine up to a lot of HP and take it to a machine shop to get hot tanked and magnafluxed. Any ideas on what that should cost?
Thanks,
-Seth
whywhyzed
Banned
Re: Chevy 350 rebuild....chip at bottom of cylinder
but you can let the machine shop tell you when they check it out
Ayuh,.......
rodbolt
with the amount of rust in that block? I would simply junk it and go find another.
I would bet the valve contact had nothing to do with the tossed rod.
the water/rust in the block would be the most likly culprit, its also whats most likly the reason the valve was stuck open when the piston came up.
Mkos1980
If you can clean it up and the shop says its good, run with it. With my stroker 383 chevy motor, we had to accually notch the bottom the cyl walls taking out alot more then that, along with pan clearancing.
rotor_av8
Maybe the pics look like it but there is a teeny tiny amount of surface rust from sitting out here in florida. You can wipe it clean with one finger swipe. It was in a truck.
I was thinking about that because I plan to make a 383 also with it.
This is a rare and valuable 4 bolt block with 1% tin added AND 2% Nickel added to the casting metal.
mkast
Grind the edges to relive stress risers. The chip is below the piston travel, run the block.
96lt4c4
That block would be fine. Even if you stroked the motor it would be fine. I would just smooth that area out so that no cracks can start. I would defiantly have it align honed.
Windykid
For the cost i would exchange for an already built 4 bolt 383.
JustJason
i see a lot of metal shavings... did a rod punch a hole through a piston?
Or.... did this thing spin a main bearing......
If it spun one... i'd probably toss it. Machine shops can fix that depending on how bad it is.... but if they have to machine the crank case and you have to buy a new crankshaft (which you probably will have to if it did indeed spin a bearing)... your better off getting a new/used set up.
Robj
Take it to your machine shop and let them decide.
Have a great day,
Rob.
Lakester
hello,
engine blocks are incredibly strong. 4-bolt sbc's are very durable. built to handle heavy torque loads on mains... such as trucks and boats. :) they can be broken, of course. from ur pix and explanations... sounds as if the block will clean up fine. cam looks ruff though, imo... ;)
let us know what u decided to do...
regards
lakester :cool:
Mkos1980
On both my cars, both are 89 Blocks from an L98 motor. One was converted to a 383 and dynos 470 at the motor and the other is a ProCharged 355 pushing 14lbs putting close to 500 HP. Both are 2 bolt mains with ARP studs. So far so good after 3 years. The key to a good engine is a good balance job IMHO
This is the 355 Block. Lunati Pro Mod Rotating with Wiseco Dished pistons. 8:3:1 "Blower Friendly"
Lakester
... not to mention good oil pressure at the rods and mains... ;)
regards
lakester :cool:
Mkos1980
Oh yea. We run a stock M55 Pump with a Z28 white spring "Mr Gasket #26 spring" for aftermarket. Suppose to give 5psi more
Lakester
hello,
sounds like it is doing its job! :)
so long as the crank dont flex! :eek: oil pumps can stand a good "port n polish" job... breaking all the internal sharp edges. champhering transition portals, etc. also running clearances tween the rotors to plate can be reduced for increased volume by dressing surfaces. oil pumps can cavitate. then u kiss metal to metal... :mad:
such trix work on the street, the strip... and on the water, too! :D
regards
lakester :cool:
Mkos1980
Yup.. We also massaged the number 5 main's oil passage.
This pics is from the 383.
rodbolt
and still no one picks up why I say scarp the block, nothing rare nor unual about it, but there is a very big reason I would walk away and spend 100 dollars on another.
