Chevy tracker v6
graduc
I know there is a lot of information out there but would a chevy tracker v6 be able to put a 20ft pontoon boat in and out of the water I am half a mile from boat slip this a single axle trailer
thanks for reading
Grub54891
A quick search shows it will tow 1500 lbs. So it should, for a short distance. I'd not tow a pontoon on the highway with it.
ahicks
For myself, I would say it would depend on the ramp. I've used some that are so steep I don't trust the trucks ability to hold when placed in park!
Most ramps though, I think you'd be fine. Point being, a little common sense will go a long way making that call.
2WD or 4WD? you may need all 4 wheels clawing their way up the ramp
oldjeep
Im going to say no way. Aside from the tow rating that is 50% too low, the thing has a short wheelbase and no weight.
MTboatguy
I wouldn't, but I also deal with some really steep ramps around here.
graduc
Thanks for your replies the the boat ramps are on the inter coastal waters near treasure island Florida. It has awd on the tracker
ahicks
Where they are at really makes no difference. You really do need to check them out in person. Later ramps, installed or re-done in the last 10-15 years are generally fine. It's the older ones, often very small, that can be challenging....
Sprig
What is the weight of your boat, trailer and motor combined? I believe you are way over the tow capacity of the vehicle. If that is the case it’s a bad bad idea to tow your boat even a half mile. And pulling it up a steep launch ramp if it’s grossly over tow capacity will likely break something like your transmission. Towing it even half a mile can be dangerous. Your brakes are inadequate, your suspension is inadequate, transmission inadequate, tires inadequate etc etc. But again it depends on the gross weight of your boat, trailer , motor and equipment.
briangcc
Assuming a 1500lb tow rating...a Tracker Party Barge 20 DLX with trailer weighs in around 3557 lbs including a tandem trailer. Granted a tandem weighs a bit more so subtract off a coupe hundred pounds. That still puts you well over your tow limit.
I wouldn't do it and would advise against attempting it...unless it's being recorded for Youtube failures under controlled conditions.
**I used the Tracker as an example as the OP didn't bother to include that information.
