I just changed the oil on my Merc 5.0/Alpha after the first 20 hours of use and something strange happened which I'm concerned about.
I had the boat on the lift and lowered the drive unit and the boat far enough that all of the water pickups were in the water - but the boat itself and the drive unit above the water pickups was still out. I ran the engine at fast idle (1500RPM) for 2-3 minutes until the temps camp up to 125 or so and shut it down. I then proceeded to change the oil and filter which went well.
Upon starting the engine, oil pressure came right up and it ran fine, however, there seemed to be a fairly loud "chirping" noise that was directly related to engine RPM coming from the front of the engine. All fluid levels including oil checked out fine. We ran the boat for 2-3 minutes and the noise went away and did not return. After that we ran for about 2 hours doing tubing duty and it continued to sound normal.
Can anyone tell me what I did to cause this, and what the noise was? Do I need to have the boat farther in the water so that the water outlets/exhaust are underwater? Really hoping I didn't hurt anything.
Thanks in advance -
Fred
Thanks in advance -
Fred
